Skip to main content
9 Messages
220 Points
Wed, Apr 16, 2014 9:18 PM
Hi Please, there is a possibility to avoid concurrent login using a WLAN with captive portal and authenticating with Active Directory?
Responses
683 Messages
11K Points
7 years ago
Can you describe your setup a little more? Do you have 2 SSID's with each providing a different authentication mechanism?
9 Messages
220 Points
7 years ago
Very thanks for the feedback Keith !
The setting is 01 SSID with just using the captive portal authentication with web ZD doing query to validate the user in an active directory database. The difilculdade being to avoid the same user login simultaneously. There is something in ZD that we prevent this?
I know that there is use of DPSK, but would like to avoid concurrent login setting in web authentication with AD, ok?
683 Messages
11K Points
7 years ago
I thought there was a setting in AD itself that either allowed or disallowed multiple logins (but what about >1 device per user which is increasingly common?)
9 Messages
220 Points
7 years ago
but Keith implement a lock so that the user has access to only 02 devices is possible using captive portal with AD? but this is exactly disallowed multiple logins.
683 Messages
11K Points
7 years ago
Hi Alex,
Sorry for the delay, this is well outside my expertise. But I did some snooping and it appears that AD or IAS aren't natively stateful and so can't "know" whether a user has 2 logins or not. But there are some add-on products that might help:
AD plugin - http://www.isdecisions.com/blog/it-se...
Alternative RADIUS server - http://www.kaplansoft.com/tekradius/
9 Messages
220 Points
7 years ago
Thank you very much Keith for the return and attention, we will try in this direction, once again thank you.
