pieter_schepens's profile
27 Messages
440 Points
Mon, Sep 14, 2020 2:35 PM
Role based Access Control Policy: how to assign a dynamic VLAN based on role?
We want to assign a dynamic VLAN based on the role of a user.
SSID settings: RBAC enabled, dynamic VLAN enabled, client fingerprinting enabled
Role settings: RBAC enabled, VLAN number filled in
The users get the right role assigned.
But still: no-one gets the VLAN of his role, everyone is stuck on the initial VLAN of the SSID.
Any ideas about what is prohibiting the assignment of the role VLAN?
Official Rep
9 Messages
160 Points
1 y ago
Hi Pieter,
We would need more details about the controller type, software version, etc.
Please log a case from the link below. However, an active support contract is must.
I hope you have purchased support contract for your controller.
https://support.ruckuswireless.com/cases/new
Regards
Santhosh
27 Messages
440 Points
1 y ago
Thanks, we'll log a case (we purchased support contract).
We're using a ZoneDirector 1200 with software 10.4.1.0 build 214.
Any advice on assigning dynamic VLAN's is welcome.
Employee
62 Messages
1.3K Points
1 y ago
Hi Pieter,
This might be helpful to you. https://support.ruckuswireless.com/hth-zonedirector#zd-8021x-auth
Karthik.
27 Messages
440 Points
1 y ago
Meanwhile, we managed to use the role based access policy on a 802.1X WLAN: the users get the VLAN that's configured in their role on the ZoneDirector or in the radius attributes. It still doesn't work when we user captive portal/Web authentication based on a radius server or Active Directory, but when we use 802.1x EAP for authentication, it now works.
Important Announcement
