Skip to main content
Mon, Aug 27, 2018 5:23 AM
Unable to authenticate every morning (spesific time)
Hi Experts..
I have 86 Access Point that have same problem every morning, most client cant login authentication and connect until 10am while some other (only 1 per 8 client) can login before that time
Im using 3 Active Directory for AAA Servers
I had try to ping each Access Point ip's reply
ping AAA server ip from Network Connectivity reply
try Test Authentication/Accounting Servers login for each AD and success
this is weird because this issue only before 10am everyday and solve itself without changing any configuration
how to check and solve this issue..
here events what I got
Responses
388 Messages
5.9K Points
2 years ago
In wired port side aaa server or controller, try to capture a packet dump.
5 Messages
120 Points
how to capture the packet dump?
388 Messages
5.9K Points
Use wireshark though mirroring.
27 Messages
404 Points
2 years ago
Any firewall rules with scheduling policies?
5 Messages
120 Points
yes.. but the filewall only drop traffic 9PM to 1AM
today I got same issue.. it's 8:45AM here and most client can't login
alarm starting to show..
update : now it's 9:19am.. 337/458 clients Authorize.. seem today they can login faster than before
388 Messages
5.9K Points
If so, it may  problem of firewall side.
Check a policy for udp packet forwarding.
ex. you can disable a policy for udp flooding.
5 Messages
120 Points
So should I allow udp flooding to solve this issue or the opposite
