ho_chee_seng's profile
8 Messages
180 Points
Tue, May 6, 2014 3:10 AM
Client Fail to Obtain IP Through Ruckus 7341 AP
I have two Ruckus 7341 AP and a ISP provided Wireless Router.
Every morning, when I connect to the APs, I would fail to get assigned IP address in time. I would wait a couple hours to get connected to the network. However, if I connect directly to the Wireless Router, I get connected instantly.
Anyone else having this issue?
Responses
Champion
824 Messages
13.2K Points
7 y ago
Hello Ho Chee Seng,
With limited info, i assume that there is NO zonedirector and you are using DHCP services of ISP provided Wireless Router and NOT of ZF7341 AP.
Your topology looks as below:
Internet ----- ISP provided Wireless Router ----- ZF7341 AP
----- ZF7341 AP
I would like to ask you below:
1. Which firmware version you are using on ZF7341 AP? if not then Please ensure that it is latest. You can check Support portal for more on latest firmware version.
2. You make things work temporarily by connecting directly to the Wireless Router. How you make things work normally as you would have expected? do you reboot something like Ruckus AP or ISP provided Wireless Router or something else?
3. There are NO VLANs in place. correct?
4. I suspect that ZF7341 AP DHCP is too used so when problem appears, please login into GUI of device and see whether enough IP are available.
I hope this helps
8 Messages
180 Points
7 y ago
Hi there!
Your assumption is correct. No zonedirector. DHCP Server on ISP's Wireless Router. Topology correct.
1. Firmware: 9.1.2.0.8 and yeah, it's the latest.
2. Rebooting (all) the devices doesn't do much. All I could do it switch my client's wifi connection to the ISP's Wireless router to get an IP instantly. Only after a couple of hours later that I connect back to Ruckus' AP that the connection is successful.
3. No VLAN.
4. DHCP comes from the ISP's Wireless Router and unassigned IP of about 30 addresses left.
Champion
824 Messages
13.2K Points
7 y ago
Firmware: 9.1.2.0.8 is too OLD. current and latest for ZF7341 is Firmware 9.7.0.0.220.
See more on link - https://support.ruckuswireless.com/so...
on standalone AP's - you can jump up from any version to any version and vice versa.
Just upgrade one of your AP's to latest and keep an eye.
8 Messages
180 Points
7 y ago
Hey, thanks for pointing that out!
I didn't pay attention to the result after googling for ruckus 7341 firmware.
Will perform the upgrade over the weekend.
Champion
824 Messages
13.2K Points
7 y ago
Hello Ho Chee Seng,
Just in case if you come across the issue again on the upgraded AP or other AP which is still on old firmware - 9.1.2.0.8
try the following during the time when AP does not give out IP
Ping that AP from wired side.
Access the GUI of that AP from wired side.
if all of the above fails then reboot it and try again the above steps
Important Announcement
