Skip to main content
42 Messages
812 Points
Wed, Jan 10, 2018 10:09 AM
Authentication problem between vSPoT and external server (endpoint). Error 401
We have installed a lockal vSPoT location server and tested it in the API Explorer and it is working fine.
Our problem is the interface between vSPoT and external analytic server.
When we send a GET request from the external server, we get an answer, that our request is blocked due to authentication:
status: 401 Unauthorized
x-xss-protection: 1; mode=block
www-authenticate: Basic realm="Ruckus SPoT"
We checked the API key double and it is correct.
May be someone faced the same problem or have an idea what is wrong...
Examples of request:
curl -i -X GET -H "Content-Type: application/json" -d'{"api_key":"API_KEY"}' https://192.168.10.218/api/v1/venues/name/devices/192.168.10.3/find.json
or
curl -i -u NAME:PASSWORD https://192.168.10.218/api/v1/venues.json
Regards
Igor
Responses
42 Messages
812 Points
3 years ago
Well, the issue is closd. It was our mistake.
The curl command used was wrong
