Skip to main content
bobby_wittenberg's profile
Tue, Aug 4, 2015 5:34 PM
vSCG / R300 request for a B/G WLAN
Hey there, we've got a request from a customer who is deploying some small tablets for a small use case.  Supposedly from the tablet vendor they require wireless connectivity via a B/G WLAN.  Sifting through our vSCG that manages the 6 R300 APs at the customer site, i can't find a clear option for broadcasting the new WLAN in B/G without the N support.  Is this configuration possible given the newer generation of the equipment we are using or is B/G just too old?  Seems silly that someone today would sell a product that doesn't support N.   They do provide a bunk B/G AP but you hate to use non-standard garbage in your clean network.
Thanks!
Responses
Champion
556 Messages
10.5K Points
6 years ago
By default, Ruckus's wlan's should be 802.11 b/g backwards compatible, unless you used the CLI to specify the "ofdm-only" configuration on the wlan (which is often recommended for higher capacity, but restricts the network to G or newer).
You might have to be cautious about using WPA2 (e.g. without TKIP), or enabling 802.11 r or k in the wlan settings. Other than that, they should support 802.11b/g devices just fine.
I've got an R700 and R600 and a thermostat and fitness scale that only support 802.11b, and they can connect to my network just fine, even with WPA2-AES.
Bottom line is, you can expect those tablets to "just work", but be prepared for a possible need to downgrade security settings, or turn off some other advanced networking settings like 802.11r/k fast transition.
Brand User
Former Employee
2.6K Messages
44.8K Points
6 years ago
Older scanners required WEP or TKIP, but all wifi devices since 2005 should support WPA2/AES.
You can configure your Tablet WLAN to use a combination of WPA-Mixed/Auto(TKIP+AES) to run B/G mode.
