Skip to main content
3 Messages
110 Points
Thu, Jan 21, 2016 3:17 PM
R710 Standalone: Problem connecting web gui after factory reset
After resetting to factory defaults it is only possible to connect via ssh.
Web gui won't let me connect with the standard credentials:
super
sp-admin
The problem stays even after fw upgrade to "Standalone AP Software 100.2.1.0.148 (R710)"
What is the the problem?
Thx in advance.
Responses
Brand User
Former Employee
2.6K Messages
44.8K Points
5 years ago
It is interesting that your credentials work for SSH but not HTTPS.
To troubleshoot, use an SSH utility that allows you to capture your session output (ie putty.exe).
Use a command from the 'help debuggroup' CLI commands.
rkscli:  support
rkscli:  support show
which will generate your support info file, and then display it to the terminal screen (that's why
you capture your output).
You'll probably then have to contact Tech Support for help analyzing the AP support info file to
try to understand if the webs process crashed, or...?
1 Message
60 Points
5 years ago
I think https is disabled by default after reset.  Try ssh to the unit and enter "set https enable'
