Skip to main content
3 Messages
90 Points
Wed, Jun 5, 2019 10:15 AM
Answered
M510 LTE CLI
Firstly, the M510 seems to be a great product. However, the LTE Status M510 information via WebUI is insufficient as it contains no information (apart from connection information). My questins is on how I can retrieve more information about the current LTE status (RSSI etc etc) via CLI?
I could not find any documentation
Juergen
Responses
Brand User
2.6K Messages
44.8K Points
a year ago
I don't see a published command reference guide, so you might look around from the AP CLI, and Help command output.
Employee
92 Messages
2.1K Points
a year ago
Hi Juergen,
Please use get lte-statistics command from the AP CLI.
Here is a sample output of this CLI and will provide you detailed statistics:
rkscli: get lte-statistics
LTE CHIP                 = EC25-A
LTE FW VERSION           = EC25AFAR05A04M4G - SubEdition: V06
TIME OF DAY              = 19/05/05,18:17:53-28
GPS STATUS               = enabled
IMEI NUMBER              = XXXXXXXXXXXXXX
SIM SELECTION            = auto
SIM 0                    = present (active)
SIM 0 MCC                = 310
SIM 0 MNC                = 410
SIM 0 APN                = nxtgenphone
SIM 0 IMSI               = XXXXXXXXXXXXXXXXXXX
SIM 0 ICCID              = XXXXXXXXXXXXXXXXXX
SIM 0 ROAMING            = enabled
SIM 0 USERNAME           = -
SIM 0 PASSWORD           = -
SIM 0 PINCODE            = -
SIM 0 TX                 = 49.45 KB
SIM 0 RX                 = 139.28 KB
SIM 0 NW REG             = registered, home network
SIM 0 RSSI               = -63 dBm (excellent)
SIM 0 GW                 = 10.x.x.14
SIM 0 DNS                = 172.26.38.1
SIM 0 IP                 = 10.x.x.13
SIM 0 MASK               = 255.255.255.252
SIM 0 OPERATOR           = AT&T
SIM 0 MODE               = 4G
SIM 0 NW TYPE            = FDD LTE
SIM 0 BAND               = LTE BAND 2
SIM 0 CHANNEL            = 800
SIM 1                    = not present (inactive)
SIM 1 MCC                = 0
SIM 1 MNC                = 0
SIM 1 APN                = defaultapn
SIM 1 IMSI               =
SIM 1 ICCID              =
SIM 1 ROAMING            = enabled
SIM 1 USERNAME           = -
SIM 1 PASSWORD           = -
SIM 1 PINCODE            = -
SIM 1 TX                 = 0.00 bytes
SIM 1 RX                 = 0.00 bytes
SIM 0 switch count       = 0
SIM 0 nw lost count      = 0
SIM 0 card removal count = 0
SIM 0 dhcp timeout count = 0
SIM 0 transmit           = 49.45 KB
SIM 0 receive            = 139.28 KB
SIM 1 switch count       = 0
SIM 1 nw lost count      = 0
SIM 1 card removal count = 0
SIM 1 dhcp timeout count = 0
SIM 1 transmit           = 0.00 bytes
SIM 1 receive            = 0.00 bytes
OK
-Ankush
3 Messages
90 Points
a year ago
Thanks Ankush,
I am fairly new to the RUCKUS CLI and having trouble to get the AP to provide the statitics via "get lte-statistics"  - see below.
ruckus(debug)# get lte-statistics
The command is either unrecognized or incomplete. To view a list of commands that you can run  from this context, type '?' or 'help'.
What am I doing wrong here?
Juergen
13 Messages
290 Points
5 months ago
I am testing one of the M510 for a client but I don't seem to be able to get any internet on it running standalone.
When I run the command I don't get any output for the current IP, Mask, Gateway, Operator, or DNS.
ATT tells me the IMEI is valid and the new SIM card I got from them show present and is the same as the one they list in their system.
Is there any other way to troubleshoot the LTE connection beyond this one command?
I don't see any other documentation on it.
I want to use this in a remote location factory where they have satellite internet and I would like to have the M510 provide backup internet in case the satellite goes down.
I have previously used a Sierra Wireless ES450 for this purpose. The APs at this location are connected to vSZ.
Thanks!Tim
rkscli: get lte-statistics-------------------------------------------------------
LTE Statistics:
LTE INTERFACE : wwan0
LTE Chip : EC25-A
LTE FW Version : EC25A_FAR05A04M4G - SubEdition: V06
IMEI :XXXXXXXXXXXXXXXXXX
GPS Status : Enabled
SIM Selection : auto
Radio connection : Not Connected
Active SIM : SIM 0
IP :
Mask :
GW :
Operator : -
DNS :
Current Channel : 0
Access Technology : -
Band : -
Mode :
RSSI : -65 dBm (excellent)
Roaming Status : not registered, searching
Country Name : USA
LTE link uptime : 0 hrs, 0 minutes, 0 seconds
SIM 0 Present : YES
SIM 0 IMSI : XXXXXXXXXXXXXXXXX
SIM 0 ICCID : XXXXXXXXXXXXXXXX
SIM 0 MCC : 310
SIM 0 MNC : 410
SIM 0 APN : nxtgenphone
SIM 0 User Name : -
SIM 0 Password : -
SIM 0 Authentication : NONE
SIM 0 Pin Code : -
SIM 0 Tx Bytes : 1152
SIM 0 Rx Bytes : 0
SIM 0 Switch Count : 0
SIM 0 Nw Lost Count : 0
SIM 0 DHCP Timeout Count : 1
SIM 0 Card Removal Count : 0
SIM 1 Present : NO
SIM 1 IMSI :
SIM 1 ICCID :
SIM 1 MCC : 0
SIM 1 MNC : 0
SIM 1 APN : defaultapn
SIM 1 User Name : -
SIM 1 Password : -
SIM 1 Authentication : NONE
SIM 1 Pin Code : -
SIM 1 Tx Bytes : 0
SIM 1 Rx Bytes : 0
SIM 1 Switch Count : 0
SIM 1 Nw Lost Count : 0
SIM 1 DHCP Timeout Count : 0
SIM 1 Card Removal Count : 0
2 Messages
70 Points
Hi Timothy,
Set the APN as 'broadband' and check.
set lte-sim-apn : set lte-sim-apn {primary|secondary} {APN name}
Sagar
13 Messages
290 Points
Hi Sagar,
Is there some documentation about how to configure these AP's LTE setup? There does not seem to be any GUI way to do this or even get status. I have loaded the standalone, Unleashed and vSZ firmware on the AP, but can't seem to find a way to manage the LTE setup and I don't seen any CLI documentation on the website.
After performing the command, it now shows the following:
LTE Statistics:
LTE Chip : EC25-A
IMEI : XXXXXXXXXXX
Radio connection : 4G
Active SIM : SIM 0
IP : XXX.XXX.XXX.XXX
Mask : 255.255.255.248
GW : XXX.XXX.XXX.XXX
Operator : AT&T
DNS : 172.26.38.1
Current Channel : 5110
Access Technology : FDD LTE
Band : LTE BAND 12
Mode : LTE
Roaming Status : registered, home network
Country Name : USA
Uplink Bandwidth : 10MHz
Downlink Bandwidth : 10MHz
RSRP : -97
RSRQ : -12
SINR : 9
LTE link uptime : 0 hrs, 0 minutes, 33 seconds
SIM 0 Present : YES
SIM 0 MCC : 310
SIM 0 MNC : 410
SIM 0 APN : broadband
SIM 0 User Name : -
SIM 0 Password : -
SIM 0 Pin Code : -
SIM 0 Tx Bytes : 314803
SIM 0 Rx Bytes : 28734
SIM 0 DHCP Timeout Count : 0
SIM 1 Present : NO
SIM 1 IMSI :
SIM 1 ICCID :
SIM 1 MCC : 0
SIM 1 MNC : 0
SIM 1 User Name : -
SIM 1 Password : -
SIM 1 Pin Code : -
SIM 1 Tx Bytes : 0
SIM 1 Rx Bytes : 0
2 Messages
70 Points
5 months ago
Hi Timothy,
Above output concludes that there is active LTE connection now. Could you confirm whether the clients are able to access the Internet?
If the AP is running in Unleashed code in factory default then you would get an option to configure LTE settings from initial setup page.
I will check for useful documentation, CLI guide and provide the same.
Sagar
13 Messages
290 Points
5 months ago
Sagar,
Thanks, I was able to get it to connect and provide internet over the LTE connection.
I still have a hard time trying to diagnose speed issues. I ran a speed test wired to the LAN port using the LTE and only got 7Mbs down and 4Mbs up with a connection that says it was excellent.
Band : LTE BAND 12
Mode : LTE
RSSI : -67 dBm (excellent)
Country Name : USA
RSRP : -100
RSRQ : -14
SINR : 9
My goal is to add this AP to a client site that currently has limited Internet connectivity via Satellite internet and have this LTE connection as a back up. It will connect to my vSZ.
I don't see any documentation about setting the M510 LTE settings via the vSZ or to which ports should be connected.
I am assuming I need to connect the WAN (PoE) port to the PoE switch that is connected to the local firewall/Internet gateway.
Then if it the AP senses no internet on the WAN port because the satellite is down, it would provide Internet over the LTE connection, correct?
Tim
