dustin_marquess's profile
13 Messages
278 Points
Tue, Apr 30, 2019 2:59 AM
LACP on R710?
I know the R700 sadly didn't support LACP, but I thought the R710 did?
I followed the instructions that I've seen online:
ruckus(ap-mode)# get power-mode
PoE Configured Mode      : AT
Power Consumption Status : 802.3at Switch/Injector
OK
ruckus(ap-mode)# set bond bond0 add eth0
OK
ruckus(ap-mode)# set bond bond0 add eth1
OK
ruckus(ap-mode)# set bond bond0 xmit-hash 1
OK
ruckus(ap-mode)# set bond bond0 lacp-rate 1
OK
However:
ruckus(ap-mode)# get bond
LACP/Bonding is DISABLED.
OK
ruckus(ap-mode)# get bond bond0
OK
ruckus(ap-mode)# set bond bond0 enable
Error: parameter error
Usage:
set bond {options}
** : bond0, ...
** options:
    - enable  : R720 Only to enable LACP Mode
    - disable : R720 Only to disable LACP Mode
So does the R710 not support LACP and ONLY the R720? https://www.ruckuswireless.com/products/access-points/ruckus-indoor/ruckus-r710  seems to imply that it's supported.
My HPe switch says that both ports are in the Trunk, so I'm assuming LACP is working, but it's disturbing that the AP says disabled?
According to https://www.juniper.net/documentation/en_US/release-independent/nce/topics/example/nce152-example-LA... I should be able to "get bond" on the AP, eg, they have:
rkscli: get bond
        Mode:           8023AD
        LACP-rate:      fast
        MII-Mon:        100 (ms)
        Xmit-Hash:      layer3+4
        Slaves:         2
        Slave-0:        eth0, ACTIVE, UP, link-fail-count: 0
        Slave-1:        eth1, ACTIVE, UP, link-fail-count: 0
OK
Both ports are up:
ruckus(ap-mode)# get eth
Port  Interface  802.1X  Logical Link  Physical Link      Label
0     eth0       None    Up            Up 1000Mbps full   10/100/1000 PoE
1     eth1       None    Up            Up 1000Mbps full   10/100/1000
Note: Read Port#N as N+1, if you are referring this CLI output with AP's "Configure :: Ethernet Ports" UI Page.
Is this a bug or is LACP really not working?
Thanks!
Responses
62 Messages
1.1K Points
2 y ago
I'm curious about this myself. However, it sounds like you are configuring the ports in a LAG (Link Agregation Group). That works without LACP just fine. LACP is there to prevent a device being connected to two switches by mistake, for example.... and other things like that. So depending on the switch settings, the LAG may work fine, even in the absence of LACP on the device side.
13 Messages
278 Points
2 y ago
Actually, no, I really do want LACP...
The HPe switch on the other end is configured for "Dynamic" (LACP) mode.. and it says that both ports are activate in the group, so it sounds like the R710 really is doing LACP.. but it seems strange that the CLI won't even show it...
Brand User
Former Employee
2.6K Messages
44.8K Points
2 y ago
We have a knowledge base article 3118 regarding LACP for link aggregation of two Eth ports on 802.11ac APs (ie R710).
https://support.ruckuswireless.com/articles/000003118
You need at least 802.3at PoE+ or a passive PoE injector capable of 20W.
13 Messages
278 Points
2 y ago
The unit says that it's getting 802.3at:
The switch is a HP PoE+ switch...
Tried even forcing:
rkscli: set power-mode atOK
rkscli: get power-mode
OK
rkscli: get bond
OK
29 Messages
498 Points
2 y ago
hi ,
Please WhatsApp me on +919985563228
thank you
Brand User
Former Employee
2.6K Messages
44.8K Points
Please open a case. It is not appropriate and Ruckus does not endorse for members to "WeChat" or "WhatsApp" or other PC-control type program interaction between unverified persons.  Please open a ticket with our Tech Support, and share your information above, so we can assist you properly.  Thanks!
16 Messages
252 Points
hi Guys
I have exactly the same problem, is there a solution regarding LACP?
Sorry for my bad English, I live in Germany and my english is not special.
16 Messages
252 Points
2 y ago
hi Guys
Brand User
Former Employee
2.6K Messages
44.8K Points
Es ist sehr gut Hans.
Have you tried the information from here?
13 Messages
278 Points
Hans: Are you running Standalone or Unleashed firmware on the R710? I have a bad feeling that LACP doesn't work with the Unleashed firmware.
16 Messages
252 Points
2 y ago
Hi
I forgot to mention that I use a DC adapter.
I am using the Unleashed firmware.
Meanwhile, I have the problem recognized, there is a (LACP) bug in the current and penultimate Unleashed firmware!
With Unleashed firmware 200.6.10.1.312 LACP works perfectly.
I hope that in the next firmware is fixed.
Between the current and the 200.6.10.1.312 firmware, there are quite a few config differences or missing some config menus.
Greetings from Germany
Brand User
Former Employee
2.6K Messages
44.8K Points
Hans, I created case #994759 on your behalf  We'd like to be sure we have filed the bug for LACP failing on R710 in Unleashed 200.7 code.  Thanks!
16 Messages
252 Points
2 y ago
Michael, thank you.
The support has already reported, I'm curious if we can solve this together.
Greetings Hans
16 Messages
252 Points
2 y ago
hi Guys
Problem solved.
The support did not give up and helped me a lot.
There is a new firmware that fixes the LACP problem.
Big thanks to the whole Ruckus team.
16 Messages
252 Points
2 y ago
hi Guys
Problem solved.
Official Rep
247 Messages
4.2K Points
2 y ago
Yes, the issue has been resolved on the 200.7.10.202.92 version.
Sanjay Kumar
Important Announcement
