Skip to main content
5 Messages
110 Points
Wed, Aug 10, 2016 1:51 AM
Answered
R700 not passing data not sure what I'm doing wrong??
The APs are on VLAN 33. They receive an IP address from VLAN 33. You can see the WLAN SSID and you can also connect to the SSID. Once connected, you are handed an ip address from VLAN 33. However, you cannot ping or connect to anything. If I SSH into the AP, I can ping anything and everything but the clients attached to the AP cannot ping or connect to anything. Its almost like the AP handed out the DHCP address and then went into "don't pass any data mode". Any thoughts why I cannot get on the network? Thanks.
Responses
14 Messages
282 Points
4 years ago
Make sure your gateway is correct...
5 Messages
110 Points
4 years ago
Which gateway? My DHCP server hands out the gateway. It's 172.16.33.1. The clients get that but cannot connect. If I plug a PC in they get the same gateway and they can connect. Or are you referring to a sifferent gateway?
14 Messages
282 Points
4 years ago
Thats the gateway I was referring to. Is the ap the client connects to the only one or are there other aps that this is happening to as well? What about other ssids? Are other ssids effected?
5 Messages
110 Points
4 years ago
I have only 3 APs installed. There will be 40 APs when finished. Of the 3 installed only one is active. I was running a test before I move on. Cannot get connected through that one. AP has 172.16.33.5, client was given 172.16.33.6. The CLI of the AP can ping everything. The client cannot ping anything.
Employee
305 Messages
4.9K Points
4 years ago
Hi Tory
Can the client ping the gateway ?
Maybe you have client isolation enabled ?
Kind regards
Martin
5 Messages
110 Points
4 years ago
The client can not ping the gateway. Would client isolation be turned on by default?
Brand User
Former Employee
2.6K Messages
44.8K Points
4 years ago
Are you running the R700 in Standalone Mode, or managing it with a ZoneDirector or SmartZone controller?
5 Messages
110 Points
4 years ago
Its running managed by a SCG.
The problem is solved!!
By default, when we create a WLAN, the setting for Client Traffic Control is set to Guest Restricted. I simply changed that to System Default and data started to be passed. It is functioning properly now.
Brand User
Former Employee
2.6K Messages
44.8K Points
Glad to hear it, thanks!
