Skip to main content
16 Messages
298 Points
Wed, Mar 18, 2020 1:02 PM
Licenses activation for APs on SZ124
Am I suppoused to see total number of APs? For example, I activated license for 225 APs first, and then I activated 135 licenses for APs. When I go to Administration/Licenses on SZ124 should the capacity number be 360? Both of licenses are permanent and activated on one controller. When I check on the controller I see first "CAPACITY AP 225", and in the next row "CAPACITY AP 135". In my experience with other controllers (not ruckus) when you activate licenses you see total number ( that would be 360 in this case).
Responses
126 Messages
2.7K Points
7 months ago
Hi Milan,
If the order has been placed by your disti to Ruckus is 360 then you seem then as one item on the controller in your case you are seeing them as twice splitted it is because, your disti has placed like this with Ruckus and so it has been delivered it this way but there shouldn't be any issues in operation.
Hope it helps!!!
Abilash PR
16 Messages
298 Points
Greetings Abilash,
Well, first I activated 225 licenses for AP, one month later I activated license for 135 more. 135 licenses are activated one month later because that is the period when I received them. I will probably find out what is happening when we join 226th AP to a controller. But from you experience there should not be any problem with that?
Thank you for your reply!
126 Messages
2.7K Points
Hi Milan,
There shouldn't be any issues, the controller is now licensed for 360 APs total irrespective of 225 and 135, when you add in 226th AP with both these licenses installed they should work fine.
In your LiMan you will see these too, let's say If you seem to have another controller working some where else which is registered under your own account you can use the un-used licenses from your first controller on the second one.
As the licenses are tied to your LiMan account it's very flexible in Ruckus, the same could be used on vSZ ( Virtual controller ).
If you navigate to System you will see the AP capacity to 360.
Abilash PR.
43 Messages
1K Points
7 months ago
In Admin-> Licenses, See "View Mode" Click Summary instead of List. You can see Total, Consumed, Available licenses.
List Mode is Transactional So you will see every license transaction there.
HTH
16 Messages
298 Points
Hi Karthik,
This is very simple. Thank you very much for your answer.
16 Messages
298 Points
Dear Karthik,
I have a little problem. When I go to Admin/Licenses and click on summary I still do not see 360, but I see this:
AP Capacity License
1585
60 (3.785%)
1525 (96.215%)
AP Direct Tunnel license
3000
0 (0%)
3000 (100%)
I am not sure why. I know that licenses are not activated under our company name but I should see them when I log in on controller? By the way when I click on "List" I still see 225, and in the other row 135. Any advice?
126 Messages
2.7K Points
Dear Milan,
Could you share the screen shot of Administration>>Licenses (View Mode:List) page ?
The 1000 are from 90 day trial licenses that come with SZ100, others can be inferred upon looking at the installed licenses.
Abilash PR.
16 Messages
298 Points
Greetings Abi,
Thank you for answering in short period. Of course I can.
126 Messages
2.7K Points
Hi Milan,
Thanks for the share, it looks good to me.
According to the licenses that are installed on this controller there are 1585 AP licenses (1000 trial (expires on May 18 2020) + 225 + 225 + 135 ) 60 are consumed. I am not really sure why you are seeing 225 licenses twice, probably checking about this with support would give us some answers.
Hope it helps!!!
Abilash PR.
