Skip to main content
Wed, Mar 7, 2018 9:01 AM
Turn off Wireless
I have a R310 and I'm looking for a way, in the software, to disconnect / pause / turn off the wireless. Is there a way as I can't see one and I've been unplugging the thing to get the resolve I want. Is there an easier way?
Responses
824 Messages
13.2K Points
3 years ago
yes and no depends on what your planning to do or acheive??
19 Messages
270 Points
3 years ago
Achieve -  I'm looking for a way, in the software, to disconnect / pause / turn off the wireless.
75 Messages
1.3K Points
3 years ago
if you have a controller like ZD1200 then you can shedule the wlan.
or you can switch on/off the radio in software on R310.
19 Messages
270 Points
3 years ago
No controller. HOW do I turn it off. I can't find a way. Please describe the path
75 Messages
1.3K Points
3 years ago
look for enable radio
19 Messages
270 Points
3 years ago
No - nothing like that. Honestly, spent ages looking at the GUI. I can't find any way which is why I came here and all i get is cryptic replies. Unless you KNOW a way for CERTAIN, please don't respond. If you do  - then describe the path. Thanks
824 Messages
13.2K Points
3 years ago
tweet...
since you are using a standalone AP... hence check this out..
goto configuration --> Radio 2.4ghz --> SSID tab --> disable wireless availability
do the same for 5ghz for all those SSID you want to turn off WiFi
hope this helps..
19 Messages
270 Points
3 years ago
Thanks for that. I think there's some confusion here since my interface is different from the above and that's probably why I'm not seeing radio anywhere.
Having said that, Services does have this but there is still no option to turn on/off.
824 Messages
13.2K Points
3 years ago
hi,
no problem, happy to help
refer to this link --> http://docs.ruckuswireless.com/unleashed/200.4/index.html#c-RadioBGN.html
this will help in turning off the radio on the AP..you can always turn it on whenever u feel like
19 Messages
270 Points
3 years ago
Perfect - that's what i was looking for.
Thank you.
824 Messages
13.2K Points
3 years ago
another way would have been to goto WIFI NETWORKS... select the SSID you want turn off and hit disable..
