Skip to main content
4 Messages
100 Points
Wed, Jan 4, 2017 6:38 AM
Mobile devices connected to Ruckus 7982 wont load videos.
Hello i have a 7982 on standalone  Software Version:9.8.3.0.14. Everything is working fine except video apps on my phones like you tube seem to be running slow and takes a long time to load. on my laptop it works perfectly fine. i dont know what the problem is with mobile devices on my network not working well with youtube.  any help would be appreciated
Responses
Brand User
Former Employee
2.6K Messages
44.8K Points
4 years ago
Does an Android device work better than an iOS mobile device?  Are you close enough to the AP to limit packet loss?
Do they have the same problem with other embedded video (like on CNN.com), or only youtube?
4 Messages
100 Points
4 years ago
both ios and android have same problem, I have tried been close to the AP . Certain video player apps are slow. For example the youtube apps on my phones will take like 15 seconds to load the thumbnails . Im not sure if its my set up since im not very experienced in networking. I just have my modem connected to my wireless router with the radios off and then the AP connected to the router. I can reboot everything and it seems to solve the problem but after 3 days it starts to slow down.
4 Messages
100 Points
4 years ago
no help?
17 Messages
384 Points
4 years ago
Hi Brian,
Please upgrade your Stand alone AP to latest release
https://support.ruckuswireless.com/documents?filter=38#firmwares
Disable multicast on the AP via CLI using below command
rkscli: set qos directed multicast {enable|disable}
rkscli: set qos wlan0 directed multicast disable
Disable igmp snooping
rkscli: set qos wlan0 igmp disable
Disable mld
rkscli: set qos wlan0 mld disable
Note: wlan0 interface used as an example. Use "get wlanlist" command to check the wlan interface and enter execute the above commands.
Prado
4 Messages
100 Points
i will definetely try that and get back to you. Thank you!
