paul_harper_8pvxaun1b1ph6's profile
2 Messages
80 Points
Wed, Apr 8, 2020 8:52 AM
Answered
Cloudpath and Azure AD SAML Authentication
We have an environment where we have got on-prem AD synced with Azure AD, we have just started to implement the cloud hosted cloudpath environment to integrate with our Azure hosted VSZ controllers
What we want to do is have cloudpath use the Azure AD as an authentication server, for BYOD and guest sponsorship. Eliminating the need to open ports to our on-prem AD servers.
I see support for google and others but no documentation for Azure AD
is it supported? has anyone else done it?
Thanks in advance
Accepted Solution
Employee
9 Messages
276 Points
9 m ago
Hi all,
This procedure is now officially documented on the Ruckus Support Portal.
https://support.ruckuswireless.com/documents/3686-cloudpath-es-azure-integration-using-saml
Employee
9 Messages
276 Points
2 y ago
Hi Paul,
    Leave your email address, and I will send you a pdf with instructions how to do this.
Thanks,
Brett Nelson
Mgr. Cloudpath Product Solutions
2 Messages
80 Points
Hi Brett, please use paul@abtec.net
Thanks for your help
Cheers
3 Messages
90 Points
Can I get the pdf also.
jwysong@hcc-nd.edu
1 Message
60 Points
Hi. I would also like ot get this PDF. Thanks
1 Message
60 Points
Could you send me the pdf too. TP050300@mail.apu.edu.my
7 Messages
130 Points
Can I get the PDF too.
vadim.ma@gmail.com
THanks!
7 Messages
142 Points
1 y ago
Can I get the PDF also.  pwilcox@cbac.com
1 Message
60 Points
We need the pdf too alessandro.zappa@innovazionedigitale.it
1 Message
60 Points
1 y ago
can you send me the PDF file too ? jscer_996@yahoo.com
(edited)
2 Messages
70 Points
Can you send to us as well.  technology@hbsslaw.com  Thanks.
5 Messages
122 Points
10 m ago
Can you send us too ? ruckus@2isr.fr, Best Regards,
2 Messages
70 Points
10 m ago
Hi
May I get that Azure/Cloudpath pdf? aionescu@smamb.ca
Thanks,
Alexandru
2 Messages
70 Points
10 m ago
Can you please send the pdf to aionescu@smamb.ca too?
Thanks,
8 Messages
202 Points
9 m ago
I'm interested in that document too. Please also send it to: ruckus@boun.cr
(edited)
Employee
6 Messages
122 Points
8 m ago
All, the SAML PDF is linked on our partner portal:
https://partners.ruckuswireless.com/system/files/dg_azuresaml_intergration.pdf
Azure AD Domain Services integration via LDAP:
https://partners.ruckuswireless.com/system/files/dg_azureadds_intergration.pdf
Here is a link to other content on partner portal:
https://partners.ruckuswireless.com/ruckus-products/product-resources/technical-competency
If you don't have access to partner portal, we also post these documents to our support site:
SAML document on support site:
Azure AD Domain Services integration via LDAP on support site:
https://support.ruckuswireless.com/documents/3703-ruckus-cloudpath-es-deployment-guide-azure-integration-using-ldap
(edited)
3 Messages
90 Points
Thanks !
Chris
(edited)
Employee
6 Messages
122 Points
5 m ago
All. You should not need a support contract to create a basic support account on support.ruckuswireless.com:
To access our support portal, please register. Basic access is free and does not require a support contract. If your product is still under it's 90-day limited software warranty, you'll get Premium access for the duration of that warranty. Additional services are available once you activate your support contract (if any)
Important Announcement
