shaun_strydom's profile
30 Messages
456 Points
Thu, Aug 17, 2017 8:00 AM
Answered
Ruckus AP's - Multicast UDP stream Issues ZF7363 and R500
Multicast and UDP stop streaming issues:
Hi All,
I've been having major issues with a Hotel/Property running ZF7363's and R500 AP's in the rooms. AP's need rebooting almost daily.
They have a IPTV solution that connects to the AP as there is only 1x Cat5e cable available to each room.
The Edge switches being used are HP5130 POE switches,
The Samsung TV's being used are Samsung AD690's hotel tv's. The TV's stream perfectly for a couple of hours and then the udp/multicast steams stop. I still have full bi-communication with the TV over the network, but no streams seem to pass through. Only after a ap reboot the streams start working again.
I have added a the following config onto the ZD3050 for each AP model being used.
Ruckus(config)# ap-group system default
The AP group entry 'System Default' has been loaded. To save the AP group, type 'end' or 'exit'.
ruckus(config-apgrp)# model r500 port-setting
ruckus(config-apgrp-port)# lan 2 qos igmp-snooping
ruckus(config-apgrp-port)# end
and
ruckus(config-apgrp)# model zf7363 port-setting
On the ZD controller i have configured LAN 2 to be an access port to Vlan 5 - which is the IPTV vlan.
The Controller is currently on Version
System View
  Uptime= 339d 12h 53m
  Model= ZD3050
  Licensed APs= 200
  Serial Number= xxxxxxxxxx
  Version= 9.10.1.0 build 59
Some assistance will be hugely appreciated.
Thank you in Advanced,
Shaun
Brand User
Former Employee
2.6K Messages
44.8K Points
4 y ago
    You might want to work with Tech Support to analyze your entire network, from the wireless clients
to the IPtv streaming source server, and sometimes different configurations can work better than others.
Please see a couple of descriptive KBA articles:
https://support.ruckuswireless.com/answers/000001236
https://support.ruckuswireless.com/answers/000006234
    Do you know the maximum total streaming clients that have been accessing Multicast streams?
I think there might be limits to how many can go thru an AP simultaneously.  Here are my thoughts.
1. Usually use the latest version of ZD firmware that supports all your models of AP.  If you can't
go higher than 9.10, your ZD could run 9.10.2.0.29 (MR2 Refresh), from this link.  Do a backup
and schedule a change management period for any upgrade.
https://support.ruckuswireless.com/software/1081-zd3000-9-10-2-0-29-mr2-refresh-software-release
2.  Ruckus uses a Directed Multicast feature, where the first 5 members of a UDP igmp group,
will be converted from UDP (best effort) to TCP (guarenteed) delivery.  This is *usually* a good
thing.  We have ZD WLAN group CLI commands that can turn off (disable) Directed Multicast,
described in a KBA above.
3.  IGMP Snooping is a third consideration.  If you don't enable IGMP snooping at the AP, the msgs
go thru to/from the wireless clients, instead of the AP acting like their proxy.  You might try turning
off IGMP snooping, if the above recommendations don't seem to greatly improve your results.
Good luck and best regards.
Champion
824 Messages
13.2K Points
4 y ago
hi
i read your post 2-3 times to understand and in a nutshell,
during good times, everything work ok i.e. stream to TV's and you able to communicate with TV via pings etc on same wifi connection. Ruckus AP is in between the network and TV's correct?
during bad times, everything is NOT ok i.e. stream to TV's stops however you are able to communicate with TV via pings etc. Ruckus AP is in between the network and TV's correct?
Is this something started to occur very recently? seems your installs is an old install..
30 Messages
456 Points
4 y ago
Good Morning Guys,
@Monnat - that is correct. I have done some additional testing, When the issue actually happens, i'm able to stream everything just fine on my macbook using VLC when i have configured a SSID pointing to the the IPTV VLan, During the test the TV still is not able to stream. But when i reboot the AP, the TV and my macbook streams just fine. I'm thinking that when the TV changes a channel to a different UDP stream, the AP doesn't send a leave request to the switch and 2 or more channels continue to stream through the AP... This causing the AP to flood and to stop all streams. When i completely bypass the AP and connect the TV straight to the switch the tv doesn't have any issues.
Let me know if there is a port fast or igmp fast leave config I'm able to add on the ap's.
Champion
824 Messages
13.2K Points
4 y ago
it may sound like dumb step however can u pls try OR TEST this...
clone the WLAN to which TV connect however on this new WLAN make sure you don't use any security or encryption... just keep it open (may be a L2 ACL applied)...keep rest of the stuff as it is like VLAN, IP etc
and see if problem persist or not...
i think ecryption re-keying is messed up b/w AP and samsung TV... just a hunch...
30 Messages
456 Points
4 y ago
Where would i need to add an IP. Don't see any option to add a IP. See screenshot of WLAN setup. just to confirm, i don't want to stream wirelessly. Stream needs to go through the Lan 2 interface. TV is Hard wired to the AP.
Champion
824 Messages
13.2K Points
4 y ago
apologies, i was under impression that TV's connect to AP via WiFi...so certainly AP is messing something up...
1 Message
60 Points
4 y ago
are you still facing the problems? i had the same problem and got it fixed
2 Messages
90 Points
3 y ago
@Stanley Hotel
Don't know about the original poster but we are seeing something very similar.  How did you solve your issue?
2 Messages
90 Points
3 y ago
Following up for anyone else hitting the thread.  On our issue, we found directed multicast needed to be disabled on the Ruckus AP port connected to the network switch stack.  Once done, the IPTV's worked perfectly.
Other possible solutions we found in other threads with similar issues:
Disable Directed Multicast on the endpoint facing port of the AP
Disable IGMP Snooping on the endpoint facing port of the AP
Disable IGMP Snooping on the backbone facing port of the AP
Enable PortFast and Fast-Leave on the network switch stack port feeding the AP.
Not directly related to the Ruckus AP's but we also found on our Cisco switches PIM needed to be enabled.  Until it was, IPTV's connected directly to the network were having very similar issues to the IPTV's connected via the Ruckus AP's.
Good luck!
8 Messages
130 Points
4 m ago
Looking for help with a similar issue, albeit residential install with Tivo estream boxes (android tv) from my local cable co. I have R500's running Unleashed 200.7.10.202.127 but can't get the estream boxes to stream. I am told maybe disabling igmp snooping but can't find anywhere in this firmware to do so. Any ideas?
The estream boxes are connected via wifi from the R500 WAPs.
(edited)
Important Announcement
