christian_bottos's profile
4 Messages
100 Points
Sat, Sep 19, 2020 9:18 PM
New firmware 200.9.10.4.202 with issue
I just updated my r610 unleashed with new firmware 200.9.10.4.202. After that my URL filtering starts not working properly.
Example: I am using youtube safesearch for childrens SSID, cultural videos are showing in the search but I can't play them.
This happen after upgrade to new firmware.
4 Messages
92 Points
1 y ago
Hi Christian
URL Filtering service requires an active URL filtering license to function. URL filtering licenses can be purchased from Ruckus partners and distributors, and a temporary license is also available to allow customers to try out the service for a limited time before purchasing.
check this manual
https://docs.ruckuswireless.com/unleashed/200.8/GUID-6E615F8C-859F-428B-87D9-7D1303FF8B44.html
4 Messages
100 Points
1 y ago
thanks for your prompt reply,
I have a valid license, I bought it 3 months ago.
The issue started when I have upgraded from 200.8 to 200.9 firmware..4 days ago
It's very strange, I can open youtube, I can search and see the result, but I can't reproduce them.
Note: I'm using Youtube Safe Search, so I'm trying to reproduce cultural videos, that I suppose are granted
With 200.8 firmware I never got any error.
Regards
Chris
Official Rep
101 Messages
1.7K Points
1 y ago
Worth checking if the YouTube Virtual IP is still the same.  You can open command prompt or terminal on your laptop to run ping restrict.youtube.com and put the ip in the box, see below screenshot.  As it only happened after the upgrade, so it may not be the virtual ip gets updated but worth checking.
Also you can try to recreate the test URL filtering profile with the same configuration, then apply to a test SSID to ensure it is not due to the upgrade process for not carrying over all the old config to the new config.
If no luck after all, time to open a ticket with the tech support team.  Hope it helps.
7 Messages
136 Points
@tony_heung I have the same issue. Using 200.9.10.4.212 that came 10/27/2020.
(edited)
4 Messages
100 Points
Hi Jeff,
You are right!! The issue continue with this version too.
Regards
Chris
7 Messages
136 Points
I have tried disabling safe search, and even selecting the lowest level filtering of 'No adult content or nudity' as well; it seems that if URL Filtering Profile is enabled on any SSID, YouTube is blocked from playing videos...
(edited)
7 Messages
136 Points
I have disabled all 'Safe Search' settings and even set the lowest level of filtering,  'No adult content or nudity' and still the playing of YouTube videos is blocked when the profile is enabled on an SSID..
3 Messages
86 Points
Still not fixed :(
Important Announcement
